Help! Add left and right sidebar for posts
Hello supported Newspaper!
In the Post settings interface I installed content is the Left Sidebar, Right Sidebar I like to add how?
I want to also display left and right sidebar.
Demo: http://www.screencast.com/t/JgFniMtqQ
You can go to settings > visual composer and enable the page builder on post pages also, like this: http://screencast.com/t/UorpqxF1j2KE
Then go to post editing panel and set this layout: http://screencast.com/t/yDuKepy1nqo
Hi Lucian!
I know the visual composer can help me add sidebar in the article. But every time I write a new post will have to use a lot of manipulation. It’s very inconvenient, you have no other way?
Please help me!
Unfortunately the theme hasn’t been designed to work using two sidebars in the same time, if you want you can alter the code from the post template and set it to show both sidebars, you’ll have to edit the single.php file to make you changes: http://screencast.com/t/eduFtYod
Unfortunately we cannot offer custom work as we work hard on the development, updates, fixes and support. You can always get a freelancer from sites like: http://studio.envato.com/ if you don’t know how to do it yourself.
