Hello, I tried all the solutions on this forum, nothing works, background ad click works only on a small portion (at the top)!
I turned off at a time all plugins inclusive cache plugin! Nothing works!
My theme is newsmag 4.2 and i need ti fix this quick, my sponsor is not too happy with this problem. You can check at androidro.ro, my website.
Thanks for your time!
Hello Cosmin,
I have inspected your website and the Background Click Ads seems to works as expected for the whole space of the theme. Please clear all the caches, purge CDN files if you are using something like this, clear all the caches and check the results.
