Help configuring Image Info Box
I’m looking to do 2 rows and 3 cols of images. I wish this to display buttons within them that a user can click and go to an external url.
I first tried using Image Box but was
limited. So I decided to go with Image Info Box which gave way more options to configure. But I really like the look of Image Box. I need help making the Info Box look closer to Image Box. Examples can be seen here: Top is Image Info Box, Bottom is just Image Box
URl
Also as I have typed on the screen shot, the title (Block Header 18) is cut off and I can’t seem to fix that.
All elements have different settings, so is very possible to can not achieve the exact layout.
You can reduce/remove the extra space if you set and “-20” margin left right -> https://i.imgur.com/zIvH4Ry.png for title please check this section -> https://i.imgur.com/7pUZEKr.png for the block header, just make sure that the margins are set well (if is need you can adjust it) -> https://i.imgur.com/amYtJKg.png
