Help creating a simple home page
This is my home page https://www.emprunter-malin.com/. I am looking to display only Flex Bloc 1 in order to accelerate the loading time.
However due to several empty columns the bloc is not displaying at full screen length https://www.screencast.com/t/UUUfKxBF.
Can you let me know how do I get rid of these empty colomuns ?
FYI here is the source code :
[tdc_zone type=”tdc_content” tdc_css=”eyJhbGwiOnsiYm9yZGVyLWNvbG9yIjoiI2ZmZmZmZiIsInNoYWRvdy1jb2xvciI6IiNmZmZmZmYiLCJkaXNwbGF5IjoiIn19″][vc_row tdc_css="eyJhbGwiOnsiZGlzcGxheSI6IiJ9fQ==" row_hide_on_pagination="yes"][vc_column tdc_css="eyJhbGwiOnsiZGlzcGxheSI6IiJ9fQ=="][/vc_column][/vc_row][vc_row row_hide_on_pagination="yes"][vc_column width="2/3"][/vc_column][vc_column width="1/3" is_sticky="yes"][/vc_column][/vc_row][vc_row tdc_css="eyJhbGwiOnsiZGlzcGxheSI6IiJ9LCJwaG9uZSI6eyJwYWRkaW5nLXRvcCI6IjAiLCJkaXNwbGF5IjoiIn0sInBob25lX21heF93aWR0aCI6NzY3fQ==" row_hide_on_pagination="yes"][vc_column width="2/3"][td_flex_block_1 modules_on_row=”” image_floated=”float_left” image_width=”eyJhbGwiOiIzMiIsInBob25lIjoiMzAifQ==” image_height=”eyJhbGwiOiI3MCIsInBvcnRyYWl0IjoiOTAifQ==” meta_padding=”eyJhbGwiOiIwIDAgMCAyNnB4IiwicGhvbmUiOiIwIDAgMCAxNnB4IiwicG9ydHJhaXQiOiIwIDAgMCAyMHB4In0=” show_btn=”none” show_cat=”none” f_title_font_size=”eyJhbGwiOiIyMiIsInBvcnRyYWl0IjoiMTciLCJwaG9uZSI6IjE0In0=” f_title_font_line_height=”eyJhbGwiOiIxLjMiLCJwaG9uZSI6IjEuNCJ9″ show_excerpt=”eyJwaG9uZSI6Im5vbmUifQ==” f_title_font_weight=”eyJwb3J0cmFpdCI6IjQwMCIsInBob25lIjoiNTAwIn0=” show_author=”eyJwb3J0cmFpdCI6Im5vbmUifQ==” f_ex_font_size=”eyJwb3J0cmFpdCI6IjExIn0=” f_ex_font_line_height=”eyJwb3J0cmFpdCI6IjEuNiJ9″ art_excerpt=”eyJwb3J0cmFpdCI6IjE2cHggMCAwIDAifQ==” category_id=”” f_header_font_transform=”uppercase” category_ids=”” all_modules_space=”eyJhbGwiOiIzNiIsInBvcnRyYWl0IjoiMzAiLCJwaG9uZSI6IjI2In0=” video_icon=”eyJwaG9uZSI6IjI0In0=” image_size=”td_485x360″ title_tag=”h1″ mc1_title_tag=”h2″ author_txt=”#979797″ author_txt_hover=”#e43f27″ title_txt=”#897171″ title_txt_hover=”#e43f27″ cat_bg=”#32c4db” show_com=”none” pag_text=”#979797″ pag_h_text=”#e43f27″ header_color=”#32c4db” f_header_font_weight=”600″ limit=”10″ custom_title=”Les chiffres de l’immobilier et la consommation” sort=”modified_date” show_modified_date=”yes”][/vc_column][vc_column width="1/3" is_sticky="yes"][/vc_column][/vc_row][vc_row row_hide_on_pagination="yes"][vc_column][/vc_column][/vc_row][vc_row tdc_css="eyJhbGwiOnsiZGlzcGxheSI6IiJ9LCJwaG9uZSI6eyJwYWRkaW5nLXRvcCI6IjAiLCJkaXNwbGF5IjoiIn0sInBob25lX21heF93aWR0aCI6NzY3fQ==" row_hide_on_pagination="yes" gap="eyJwb3J0cmFpdCI6IjEwIn0="][vc_column width="1/3"][/vc_column][vc_column width="1/3"][/vc_column][vc_column width="1/3"][/vc_column][/vc_row][vc_row tdc_css="eyJhbGwiOnsiZGlzcGxheSI6IiJ9fQ==" row_hide_on_pagination="yes"][vc_column][/vc_column][/vc_row][vc_row tdc_css="eyJhbGwiOnsibWFyZ2luLXRvcCI6IjQ4IiwiZGlzcGxheSI6IiJ9fQ=="][vc_column width="2/3"][/vc_column][vc_column width="1/3" el_class="" is_sticky="yes"][/vc_column][/vc_row][vc_row full_width="stretch_row_1200 td-stretch-content"][vc_column width="2/3" tdc_css="eyJwb3J0cmFpdCI6eyJ3aWR0aCI6IjY1JSIsImRpc3BsYXkiOiIifSwicG9ydHJhaXRfbWF4X3dpZHRoIjoxMDE4LCJwb3J0cmFpdF9taW5fd2lkdGgiOjc2OH0="][/vc_column][vc_column width="1/3" is_sticky="yes" tdc_css="eyJwb3J0cmFpdCI6eyJ3aWR0aCI6IjM1JSIsImRpc3BsYXkiOiIifSwicG9ydHJhaXRfbWF4X3dpZHRoIjoxMDE4LCJwb3J0cmFpdF9taW5fd2lkdGgiOjc2OH0="][/vc_column][/vc_row][/tdc_zone]
Thanks in advanced.
By editing a page with TagDiv Composer you could delete elements but also the row called “Empty column”.
You could try to delete it like this: select the row, press the button delete from your keyboard, then with your mouse select “YES”.
Also you have another option too, check this: https://www.screencast.com/t/pxuOzYIIpcG
Hope that helps you!
