Hi! I’m using newspaper (craft template https://demo.tagdiv.com/newspaper_craft_ideas/), and I would like to have an about me box the same as the home page on this template.
I have two things frustrating me:
The author of the page is not a real person, it’s the support person I paid for when I bought the theme. So, how can I:
a) change the author of the home page
b) create a very SIMPLE author template. I’ve been to Cloud library and it’s so complicated. I just want to be able to add a photo, my name and a small blurb. And I want it to look similar to the template linked above
I would be so grateful for your help as I’ve been at it for 3 hours and getting nowhere.
Very nice looking website 🙂
If you loaded the template parts from the cloud, when you go to ‘all templates’ in your WP you will see the templates elements you are using and under each one, Edit Trash Copy Edit With TagDiv ! This will load the element in the tagdiv composer you then you can change all what you want and even replace the About Me with the Author Box
