Hello, I am getting errors when trying to save and edit posts, and the errors have to do with the Visual Composer plugin. My site is http://www.dauntlessjaunter.com, and I am still using the last version of Newspaper, not the latest 4.0.1.
The error reads when trying to save draft or schedule:
Warning: Invalid argument supplied for foreach() in /home4/domain/public_html/wp-content/plugins/js_composer/include/classes/core/class-vc-base.php on line 330
Warning: Cannot modify header information – headers already sent by (output started at /home4/domain/public_html/wp-content/plugins/js_composer/include/classes/core/class-vc-base.php:330) in /home4/domain/public_html/wp-admin/post.php on line 235
Warning: Cannot modify header information – headers already sent by (output started at /home4/domain/public_html/wp-content/plugins/js_composer/include/classes/core/class-vc-base.php:330) in /home4/domain/public_html/wp-includes/pluggable.php on line 1121
First, my Visual Composer settings were switched to work on posts as well as pages, and then I turned that off, but to no avail. This has never happened before, and I haven’t changed anything. Does anybody know what’s going on?
the errors should not be there, here are some steps to try to fix it:
– make sure you have the latest version of the theme
– disable all the plugins
– the theme markup is modified by some minify proxy or plugin. If you have some feature from your host that minifies the html, please disable it for testing.
Hope this helps,
Radu O.
Some reason it had to do with one specific photo I had, which I’ve never encountered before. It’s all working now, though. Thanks!
