Help – fonts (and colors) are not saving under theme panel
My Theme Panel settings (especially fonts under Theme Fonts → General) are not saving.
When I click Save, it appears saved, but after refresh the values revert back.
I am on PHP 8.5 and memory_limit is 2048MB.
Could this be related to max_input_vars or server configuration?
In about 99% of cases, this issue is related to caching on the backend—most commonly object caching.
Please check whether any caching is enabled for logged-in users on the dashboard, especially object cache. If it is enabled, disable it and clear all caches. Also, make sure to delete the object cache file.
