Help for inclusion in the post © ALL RIGHTS RESERVED
Dear Support,
I wanted to ask how I can only add to the end of the post the following wording:
Thanks for help and good work
You can edit post template that you use and your words in a div so you can customize(if you need): http://screencast.com/t/sfr7Amq3Rdoy
Result: http://screencast.com/t/hQ07VzUz4Un
Hope this helps!
but does not take the symbol
� ALL RIGHTS RESERVED
and not the symbol ©
You can help me
Thanks…
You can use the ASCII code for the copyright symbol …
& # 169; (no spaces)
sometimes you can also get away with the html entity, & copy; (no spaces)
Thanks for help
good work
