Help for placing affiliate deep generator link
Somebody can help ?
I need help about for tutorial step by step to put my affiliate deep generator link into the website.
I do not understand coding. Where can I find this <body> tag, in what menu if i’m using newspaper theme
thanks
There is no detailed tutorial that I can give you for this. You should follow the instructions provided by the generator you are using. It must contain some information about where exactly to place the required link.
I don’t know what that link is supposed to do, so I could not say where it should be entered. Maybe you can find this topic useful
– http://www.wpbeginner.com/plugins/how-to-add-affiliate-links-in-wordpress-with-thirstyaffiliates/
Hi Simion,
Let me upload a screenshot here
actually the instruction from my affiliates website is very less
Less instruction in marked
hope this screenshot can make more clearer question of mine
many thanks
regards
david
Add to the footer.php file.
Thank you Chris
Best Regards
david
