Hello there,
I have a problem with fonts. Although I disabled Google Fonts in “Theme Panel > Theme Fonts > Google Fonts Seetings”, requests are still sent to Google.
I use Newspaper 10 without the “tagDiv Standard Pack-Plugin”.
There are 2 versions of my website:
• Version 1 with Newspaper 9.8: Fonts are not loaded from Google
Example: https://imgur.com/7oGdZO9
Pingdom: https://imgur.com/4EsFyVZ
• Version 2 with Newspaper 10 loads fonts from Google?
Example: https://imgur.com/n1XHgQ3
Pingdom: https://imgur.com/dMybF6a
I have set the same fonts in version 2 as in version 1.
As I want a faster website, I would like to do without Google fonts. How do I manage not to load Google fonts?
Thank you in advance!
Unfortunately that option is not apply on cloud templates, if you are using cloud templates you’ll need to edit theme end change the fonts manually -> http://prntscr.com/pv8byt, sorry!
Thank you a lot!
So my homepage, the header and the footer are finished now. I set all fonts on default in all of them. But when I’m checking the homepage on pingdom, there are still some google fonts loading. I really don’t know, where I could have forgotten it :/
Is there any way, so I can find out from where the google fonts are coming from? Or any other option to fix this?
Here is the URL: https://bwgwgi.myraidbox.de/
maybe u can find where the google font is loading and where to disable it. I searched for more than 2 days and cant find a solution.
from what I can see now only the fonts for roboto -> http://prntscr.com/pwsatv and opensans are load -> http://prntscr.com/pwscch indeed there are few versions.
Hi Calin, I see it too, but I don’t find the place where it’s active. I already deactivated everywhere, but it’s still loading. Do I miss something?
So you deactivate the google fonts from theme panel and set the default fonts on desktop page and there are still some fonts that are loading, please make sure that you clear all cache.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login. We will take a look. Include a link to this topic in the email.
