Help! Got a big white space below a block and need to get rid of it.
For some reason on my live website, I have a lot of white space below Block 6. But when I go to edit it in TD Composer, everything looks fine. The white space isn’t there and things are formatted fine.
Let me know if you need a screenshot.
Hello !
Please provide either a screenshot with your issue or a link to your website would be more usefull so we can inspect and offer the proper solutions.
Hi Vlad,
Sure, the link is here: https://landoflance.com/
The big white space is right under the Podcasters section and above the Entrepreneurship section.
Hello !
The issue is that your sidebar is longer than the content block. You can fix that either by moving one of the marked blocks inside the content or you make your sidebar shorter. https://www.screencast.com/t/PPNtfYODsN
Thanks, Vlad. That fixed the problem!!
Can you also tell me how to get rid of the black comment counting “bubbles” on the home page below each title? And I want to get ride of it displaying “Author: Lance” on the home page as well.
Hello !
Sure ! For the comment counter and also the Show Author Name you will have to go into Theme Panel – Block Settings – Meta info on Modules / Blocks and deactivate them: https://www.screencast.com/t/lHs6nmnQ
Vlad,
Thanks so much. I was able to fix with your help.
Can you take a look at the attached screenshot and see the questions I ask and answer them for me? Thanks! https://photos.app.goo.gl/aVcowGox46S895Yt6
Lance
Hello !
For the date to reappear you will have to add it from the tagDiv Composer Elements like here: https://www.screencast.com/t/4Wn2KP9X once aded you can edit it through the composer css.
Unfortunately we cannot help you with your view all button since it requires custom work and we cannot offer it due to our support policy: https://tagdiv.com/newspaper-theme-support/
Hi Vlad,
I don’t really want a separate header date component. I was talking about the block meta info (date) is getting cut off. Need a fix for that.
Hello !
Sorry for missunderstanding your issue !
It appears that all of your blocks are cut off: https://www.screencast.com/t/arPvQL3otznj You will need to remove that 50 margin on the blocks. You can do that by editing the blocks using the tagDiv Composer in the CSS Tab like here: https://www.screencast.com/t/bhhBHrv9
Let me know if this works now !
Hi Vlad,
The problem is that I put the 50 in there to align the blocks correctly. See what happens when I remove the 50? landoflance.com
So for instance, when I take the 50 out, you can see that the blocks aren’t really aligned. See how FEATURED section and JUST LANDED section aren’t aligned to the left properly?
What I’m trying to achieve is exactly what babylonbee.com has done with their alignment. They have the same Newspaper theme as I do. See how everything is nicely aligned to the left?
Hello !
Please contact us via email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
