Help! Header Manager problem. Won't let me reset to original.
So I decided to try the Header Manager. I didn’t like it so I exited out without saving. To my shock, I now have a completely random logo/header/menu. It has stayed even though I didn’t save it and even though I deleted the cloud template it was based on. When I tried to revert my hompepage to an earlier revision, it has made no difference. My settings are the same so I don’t understand.
Website: http://danielpaulchristie.com
Thanks,
Daniel
From what I can see it is only in the homepage. Edit the page with the composer and check what is selected in the header manager – http://prntscr.com/mthjcp
Select the global template there if a different one is selected. Let me know if that solves it.
Thanks for reply, Simion!
Yes, it is only homepage. What is really strange is that there are no only options under Header Manager beyond the Global Header or No Header. So the homepage and my other pages look as though they are on the same setting, but clearly the results say they are not. Here are some screenshots to show: https://prnt.sc/mtn80j and https://prnt.sc/mtn8ap.
So the problem remains. I was able to edit it to make it look similar, but I cannot get it to take off the sticky menu (even though in my Theme Panel it is off). So if you scroll down on the homepage, it shows the different menu that the template set by default.
Thanks,
Daniel
Then it could be that the header is built directly in the page, delete all the elements from there – http://prntscr.com/mtx9ou
In the header manager leave it on global. If that is not it, please send us an email at contact@tagdiv.com and provide admin login, we will take a look at that page. Include a link to this topic in the email. Let me know.
Thanks, Simion!
I deleted all the elements as you suggested, switched it in Header Manager from Global Header to No Header, and then from No Header back to Global Header, and it restored the old one. So everything is good.
Thanks again!
Daniel
