HELP: Images not showing images in desktop
I dont know what happens the images just dissapear from the website, but they work in mobile.
http://www.nbnoticias.com
  • This topic was modified 11 years by kannox.
I have checked your site and the images appear on your homepage – http://screencast.com/t/yrtdd4yn4dT
Also if you Photon feature from Jetpack, please disable it. The jetpack photon feature can cause issues and while the theme works based on the same system (creates and serves/uses thumbnails for each uploaded image). We don’t recommend using that photon module as it tends to create issues sometimes so we suggest you disable it.
