help – insert button into a column
Good morning,
I have a problem. I can’t get the button into a column.
if i try to do it from the composer, i just insert it outside. i should insert a button to download a resume.
I enclose the image for a better understanding.
Thank you
https://www.dropbox.com/s/ltwdlxrol8nhbax/bottone.jpg?dl=0
Please notice that you can not add a button on “team member” element, you can add it only under or above -> http://prntscr.com/pyn6gc you can add a link on this element like this -> http://prntscr.com/pyn9zs -> http://prntscr.com/pynac2
you’re absolutely right.
Thank you very much.
Samuele
