Help… we installed Newspaper theme and it was working yesterday but today the site was really slow to load and then I got locked out. What can I do to fix this?
Diana
Check your hosting account for error log is likely best place to start if your website is totally offline. If your site is live, but you cannot login, that is whole separate issue unrelated to theme.
If your site is “overloaded” and crashing you likely will need to do couple of things
a) increase memory allocated via php.ini if not already done
b) edit wp-config.php to increase WP default memory from 40MB to 128MB (or 256MB if you are allowed on your system).
Thank you Chris,
Our host (BlueHost) did find an adjustment to the php version that they corrected plus we are migrating to a dedicated server tonight. Having lots of traffic to the site is a good thing if you can handle it.
Appreciate your time and quick reply!
Kindest Regards,
Diana
