I’m having difficulty locating where the homepage section titles (the labels above the news blocks) are edited.
I understand they are part of the Newspaper theme setup, but even after checking the Home page in tagDiv Composer, I can’t find the exact block or setting where those titles are controlled.
Could you please point me to the exact location (page, block, or theme panel section) where those labels can be edited, or guide me on what to click to access them?
Thank you for your help
If you are referring to the block titles, then you need to edit the homepage using tagDiv Composer, select the block and check in the general tab the title you can remove/change it after your needs – https://i.imgur.com/532B75W.png https://i.imgur.com/qorxsCT.png
If this is not what you mean, please let me know!
