The edit post template on my panel is different from the tutorial.
I would like to know how do I activate this option so that I can better edit my texts.
Please I don’t know how to do this.
In yours Tutorial OK >>>> https://i.imgur.com/oE7Lpha.png
IN MY WEBSITE NO OK >>> https://i.imgur.com/H0xwQTY.png
HELP ME PLEASE
You need to extend it by clicking this: https://www.screencast.com/t/fFh6yPTUy9 . When is disable, it shows just the first line of settings.
Hello good afternoon.
I’m having trouble organizing the banners under Cloud Post Templates.
The banners are getting next to each other and it looks really bad.
How do I choose the Paragraph number in which I really want to place the banner?
thank you
https://noticiadehoje.net/politica/bolsonaro-diz-que-a-escolha-de-seus-ministros-e-contra-a-currupcao/
IN MY WEBSITE : https://i.imgur.com/1XBajC7.png
Hello @iLayon!
You can manage the ads from here: https://www.screencast.com/t/7m2SLqWvgav3
The ad that you will place here will show on all posts which means that you can not put different ads on specific posts, after a different paragraph in each time.
Hope that helps you!
Hello .. Good night .
Thanks a lot for the help . I did it!
Please, I would like to know how I can activate this option in my texts. I’ve looked everywhere and I can’t find anything that explains how to do this.
If you can help me I appreciate
EXEMPL : https://i.imgur.com/GznJIro.jpg
Site using this function : https://www.jornalcontabil.com.br/quem-pode-sacar-dinheiro-da-conta-de-um-familiar-falecido/
