I published a post and logout.
By the way, why can I modify a published post… OTL
COMPLETELY OPENED BLOG?? haha…
Below video, NOT EDITOR PAGE. anyone can do that
What exactly do you mean by that? That anyone that visits the website can edit your posts? That would be a major problem if it happens for you. By default WordPress posts can only be modified from the backend post edit screen, by a logged user (author role and above).
If that is really happening for you, I suggest you check your plugins, WordPress modifications etc.
