I just installed Newspaper theme in my website, PanduanSaya.com. Just finish my edits but I found out a few things not working properly:
1. My mega menu not showing sub-categories. I followed the tutorial but can’t get it to work
2. My ajax filtering or pagination in block (homepage) not working properly. I clicked the next/previous, but somehow it takes to the top of website, and the ajax does not change the page that it should be – it just takes you to the top of the website.
3. My news sticker also having the same problem like ajax filtering in block.
Here are few of my settings, hope it helps:
– I disable lazy load, because it causing my images not showing
– I tried optimized pre-loading in mega menu preload, not working
– page attribute for my homepage (visual composer) is default template
– I use Incapsula CDN
Update!
I somehow fix this problem myself.
It turns out that my settings in WP Total Cache plugin that caused this problem.
If you’re using WP Total Cache and having this kind of problem. Kindly follow this steps:
Option #1
1. Go to your general settings in WP Total Cache
2. Set Minify setting to Manual
3. Then go to the Minify tab (on the left panel)
4. Disable CSS minify (Make sure the box for “Enable” in unticked)
Option #2
2. Disable Minify
Option #3
Deactivete WP Total Cache and just install/use WP Super Cache as recommended by tagdiv
Do any of the 3 options above can solve all the problems I stated above.
I use WP Total Cache for a few years now, and I’m kinda accustom to the plugin, that’s why I’m not planning to change it to WP Super Cache.
Hope this helps.
CASE SOLVED.
