Help please: images on site are not loading
Hi There
Can you help me please as images on Managemagazine.com are not loading.
Thank you
And it is updated BTW
I’ve checked your site and noticed that you’re using an older version of the theme: http://screencast.com/t/Xfl726Qg3R After WordPress updated at V 4.5 there appeared a jQuery conflict in our theme. We fixed this conflict and the current theme version available on themeforest works fine, also we included last version of Visual Composer plugin.
Try to update the theme at current version avalable on themeforest, also update Visual Composer at V 4.11.2 following our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ – https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/ deactivate all other plugins, clear all caches and test again.
I hope this helps.
Thank you so much Andrei for your response. I will try to find someone who can help me with this.
Have a great day.
Best
Vibeke
Hello TagDiv,
I was running the same issue when I create a post. I upgraded to the latest version and the issue (image not showing on the post) is still on-going. How can you help?
Pierre
  • This reply was modified 10 years by pkpoteau.
Please provide your site url so I can have a closer look at this issue. Meanwhile try to deactivate all plugins except Visual Composer, clear all caches, purge cdn files if you’re using then test again.
ok it’s done URL is: http://www.pierrepoteau.com
I’ve checked your site and you’re not using our theme: http://screencast.com/t/zCLhM7KcbOgC Let me know when you’re using our theme and I will inspect the site in shortest time possible.
