Help Regarding Mobile Appearance
Hey guys, I’m using “Edit with TD Composer” to create my website this time (http://jcpremierphotography.com), and I love the way it looks on the desktop, however, on mobile, there is a big gap after the first picture. You can see the difference in the screenshots below. How do I fix this?
I activated the tagDiv mobile theme to see if it would help, but it didn’t. Any tips?
Desktop: http://www.screencast.com/users/FanInsider/folders/Default/media/e736467c-8a66-42ae-8ba1-ecf27969aab5
Mobile: http://www.screencast.com/users/FanInsider/folders/Default/media/389de73a-f893-42f0-b3ab-e0ebb28c982b
Best,
Justin
Hello Justingiles,
I have inspected your website and I saw that you have added some custom rules which break the theme, sorry! You should disable that padding top and bottom from here -> https://www.screencast.com/t/DZjvntnHa and after you have added a background-image in your ROW you should check the Full height ROW from here -> https://www.screencast.com/t/nTCmtHqtyRfK
