Help Regarding Related Posts Section at the End of Posts
On each post at the end, there is a related articles section. It shows three articles in one row (because I have a sidebar) that are text only. Below that are the regular blocks that can be changed in the theme panel such as the author card, previous/next post, etc. Then, there is another ‘related posts’ section that includes pictures. This related posts section can be edited and controlled within the theme panel, however I cannot find any setting for the related posts section that contains text only and appear directly at the end of the post. I would like to turn off or remove the related articles row that is text only at the end of the post. Any help in finding the settings/code would be greatly appreciated. Thanks in advance.
Follow the links below to see a sample post and annotated images. Scroll to the end of the post to see what I am talking about.
http://www.thatemsguy.com/10-essentials-steps-to-getting-accepted-pathway-to-paramedic/
http://www.thatemsguy.com/wp-content/uploads/2015/10/thatemsguy_delete.jpg
http://www.thatemsguy.com/wp-content/uploads/2015/10/thatemsguy_keep.jpg
I cannot access your website it just redirects to the maintenance page. There should be only one related posts by default. Let us know when we can access your site.
The site is now accessible.
The feature does not come from our theme, but rather the Jetpack plugin: https://jetpack.me/support/related-posts/customize-related-posts/.
Check the plugin settings and remove it from there.
Perfect! Thank you so much for your time and help!
