[help] Revolution Slider date problem
here is the problem : http://www.screencast.com/t/gG6gDeKJJdt5
the time that show in slider is different with the real post time, i think the slider is using UTC time.
how to set the slider using local time?
this is my slider setting : http://www.screencast.com/t/3wNMS5oSmrdn
and this is my wordpress time setting : http://www.screencast.com/t/jM9g6hF4G5
thankyou 🙂
I’ve tested the time format with Revolution Slider on my side and works fine: http://screencast.com/t/ldpciOKuVt – http://screencast.com/t/e0AMlMir Try to deactivate all plugins except Visual Composer and Revolution Slider, clear the cache and test again.
Let me know how it goes!
hello Andrei..
i’m sorry, i mean the problem is in the Time, not the date http://www.screencast.com/t/gG6gDeKJJdt5
i’ve try to deactive all plugin except Visual Composer and Revolution Slider, clean browser cache, and test again. still have a trouble 🙁
By default Revolution Slider get the UTC time zone even if you set a different time zone in WordPress settings: http://screencast.com/t/BZ6Wqc8d To change that you need to edit revslider_slide.class.php file from /your-site-name/wp-content/plugins/revslider and add this line like here: http://screencast.com/t/JWlf8J5Z8DGr
$postDate = get_the_time(get_option('date_format'), $postID);
The result should be like here: http://screencast.com/t/Wh9VowbPepLM
thankyou sooo much Andrei, it’s working 😉
