Help! Sidebar has disappeared!
Hi Support –
The sidebar has disappeared from ALL of our posts/articles!
https://timandjulieharris.com/
Where I can check to make this this is enabled?
Hi…
I have the same issue and am broke my head looking the issue but now i see another member have same issue.
Hi…
Nevermind – somehow the “default” widgets got lost when I upgraded the theme. Fixed now, they were still there, just moved into “inactive” status
Hi Timventura…
how you fix the issue?
The sidebar is the widgets – go into widgets and re-add them to your “default” widget area
I did but dont work 🙁
but anyway thank you. I am wait for support now.. thank you my friend! 🙂
Hello oshershalom,
The @timeventura is right! All the sidebars were moved in the bottom section of Widgets area, to the Inactive Widgets, like this -> https://www.screencast.com/t/cKcgjLS6eTkl Notice that the theme puts them there but if are not there, I do not know, sorry! If you are using some untested plugins, try to disable all of them and install only the plugins that come bundled with the theme core files and rule out any conflicts.
Is not work. The issue is on widgets section, dont show the option to add widgets only the newspapers default and footer 1 the other dont show in http://www.oshershalom.com/images/screencapture-oshershalom-wp-admin-customize-php-1496404694655.png
You have to go to the widgets section as mentioned and there you will see all the available widgets to create a sidebar, or the inactive ones from previous sidebars
– https://www.screencast.com/t/d7dxcSQfV
Check the inactive widgets section – https://www.screencast.com/t/Xf7qnMQ5Ce
You can use the primary category to set a sidebar for the posts, so you don’t have to manually set one for each of them
– https://forum.tagdiv.com/primary-category/
