Help: Social icon and thame error
1) There’s space b/w my main manu and news sticker. i have tried to remove it move it but i can’t get right. my siteNaijaViva
2) The social icon coding has an error on the top header (fb, twitter and all) pls check http://www.naijaviva.com and click on the facebook icon on top header to see the error.
3)I dont know how to install forum to my site. i have installed bbpress plugin, but yet i cant configure it. Please Help..
That space appear because you’re using page builder + titles as page template and your page doesn’t have a tile. You can change the post template from Visual Composer pagebuilder: http://screencast.com/t/a1z0BO89l
Thanks, one problem solved 🙂
but what about
4) my site width have changed. please how do i get it to default mode? i want to increase site width
2. I’ve checked your site and noticed that you didn’t added the correct link for your facebook page: http://screencast.com/t/R9e4AKSp4J Try adding your page like this: http://screencast.com/t/7UGxp77eP2L It should work fine: http://screencast.com/t/3iYa3g7FWt
3. After bbpres install you will have an option which allow you to create a new forum: http://screencast.com/t/S8AfV3E3Sw also you can creat and manage topics and replies from the dashboard. More information in can be found in plugin’s official documentation: https://codex.bbpress.org/step-by-step-guide-to-setting-up-a-bbpress-forum/
4. The theme have a fixed width for page/ post contend which is: 1021px and for your site is the same: http://screencast.com/t/hF6dJiaJ
Hello Andrei,
Thank you for your assistance.
2. (Social Icon) The problem is not from the link i placed. i placed https//www.facebook.com/naijaviva for Facebook social icon and https//www.twitter.com/naijaviva for Twitter social icon yet is not working. when i hover over the social icons i see links like this “naijaviva.com/https//www.facebook.com/naijaviva” for facebook and “naijaviva.com/https//www.twitter.com/naijaviva”. i think the issue is from the source code (theme codings), because as i said earlier i only placed https//www.facebook.com/naijaviva AND NOT naijaviva.com/https//www.facebook.com/naijaviva
3. I DON’T KNOW HOW TO LINK THE FORUM TO THE TOP MANU AND REGISTRATION (AM STILL WORKING ON IT, AM NOT A PRO, THIS IS MY 1ST WORDPRESS EXPERIENCE)
4. FIXED! THE THEME WIDTH WAS CORRECT. THE ISSUE WAS MY SIDE WHICH I CORRECTED YESTERDAY..
PLEASE HELP ME WITH THE FORUM AND SOCIAL ICON LINKS
THANKS!
2. You didn’t insert the link correctly: http://screencast.com/t/gfdl6h2UMO
Try this links: https://www.facebook.com/naijaviva – https://twitter.com/naijaviva should work fine.
3. You can add a forum in top menu from Appearance > Menus: http://screencast.com/t/gtSJcckJJ just create a forum then navigate at the indicated section, don’t forget to save the changes before you refresh the page.
Hello Andrei,
Thank you for your assistance. the social icon is working properly now.
Am still working on the forum.. i will get back to you soon with feedback
Kelvin
