I have 3 problems and I need your help.
Problem 1: How can I hide the views and comments: https://www.directupload.net/file/d/6087/famwekg2_jpg.htm
Problem 2: The YouTube numbers are not displayed although everything is correct: https://www.directupload.net/file/d/6087/fzjg2zgb_jpg.htm
Problem 3: Can I also use the tagDiv Composer for posts or can I only edit pages with it?
Big Thanks for helping.
1. If you want to hide the Single Post Views and Single Post Comments Counter for a specific device, you hidden from CSS tab, select device -> element -> CSS => https://www.screencast.com/t/dBVQ24FZ, or if you want to remove them you select the elemnt and with a right-click you can delete => https://www.screencast.com/t/6WnNGq6NFx , or selecting the element and with drag & drop place into the deleting red zone from the bottom right of the page.
2.Please make sure you have set the youtube API like in our guide https://forum.tagdiv.com/youtube-api-key/ and check after if the problem persists.
3.tagDiv Composer is a page and cloud builder, it can be used only for pages and cloud templates, therefore you can use it on a single post template from tagDiv cloud library to adjust the layout, but not to write the post content, for this, you need to use the WordPress editor.
You can edit the page with TD Composer in WordPress->Pages => https://www.screencast.com/t/AMOjYCA7Q7p, or in front side.
Hope this helps you!
As I said above => https://www.screencast.com/t/gzxQ2QRtXA , with tagDiv Composer => https://tagdiv.com/tagdiv-composer-page-builder-basics/ you can’t edit the content of a post, you can only adjust/add the elements in the single post templates, other cloud templates and pages.
You can’t create/edit post content with the theme builder.
How do I get into the editing of posts pages as shown here?: https://www.screencast.com/t/dBVQ24FZ
I would like to remove the counter as shown in the pictures.
If possible, please provide detailed instructions with pictures.
Big Thanks
If you have a Prebuilt Website Pro, open the single post template and will you see this options => https://www.screencast.com/t/wvJLLFav
Maybe this video helps you to understand more better -> https://we.tl/t-wIZxPAB4A0
In the future, please try not to reply multiple times in the topic if possible, this will only delay our response. Replying multiple times will refresh the topic date and move it to the back of the line, we answer from oldest to newest.
Note that at the moment the Support team is not 24/7 available. We answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2
