Until now, I had been working with the Magazine Pro template for my website design. However, after watching the video you shared in your previous response, I’ve decided to start the design from scratch using the Newspaper template from TagDiv. I need some guidance to ensure I’m proceeding correctly:
I have several posts already edited with Elementor Pro. Will these posts still work if I redesign the website from scratch?
I do not wish to use Gutenberg. My plan is to input all the posts using the Classic Editor before starting the new design. Is this the correct approach?
Once the posts are created with the Classic Editor, I understand that I can later assign them to the templates I design with TagDiv. Is this workflow appropriate?
Are there any plugins or settings I need to activate or deactivate to avoid issues during this transition?
Can I communicate with support in Spanish?
If there’s anything else I should consider or any advice you can offer regarding this process, I’d greatly appreciate it.
Thank you very much for your assistance!
Best regards,
C.P.
If you have the posts created with Elementor and disable the Elementor plugin, then there will be an issue with the design and functionality you have made with Elementor on the posts.
In the Gutenberg editor, there are more options, but you can use which you want.
Yes, you can apply your cloud template to the posts. You can also use global templates and set them to be from panel -> https://i.imgur.com/QFTuZzK.png, and set the global template here https://i.imgur.com/HM0DdSD.png or in the frontend.
It depends on what plugins you have now installed and activated.
Thank you very much for your help! I’ve addressed my remaining questions in the other post on the forum where you also replied. I truly appreciate your detailed guidance and support.
