Please help, this my site : http://www.gabega.com
On the home page is use visual composer page CSS, but i don’t know what is happen, the Thumbnails of the homepage is gone, not showed.
And also about the mega menu on homepage, mega menu function is not funtion. But if i click or choose one category or single post, the featured image that i set as a first image for my content is showed, and also, the mega menu is okay. Just in category page and single post. Not In home page,
Please help, why this happen, i have been tried to regenarate my thumbnails, but the thumbnails still not showing on my homepage.
thank’s so much, before
laeban
I’ve checked your site and the thumbs are displayed fine now: http://screencast.com/t/2zkqDXruOFP0 Also the mega menu works fine: http://screencast.com/t/JuBB0n7bMi5T
If you still have this issue try to clear all caches and test again.
Let me know how it goes.
Thanks Andrei L,
Not the live homepage right now that i mean, from setting,
Just now i was change the Front page Display,
Before it, i use this page as my front page display see this : http://www.gabega.com/news
There is no Thumbnails
And if problem of this (http://www.gabega.com/news) page hasbeen solved, i will change the front page display to use this (http://www.gabega.com/news) page (with visual composer) as my front page display.
This issue usually happens due to possible conflicts between theme’s lazy load script and some plugin. Try to deactivate all plugins except Visual Composer, clear all caches including browser cache and test again. Also you can try by turning off the lazy load animation from theme panel > template settings: http://screencast.com/t/3atzWAxqg9
Try to deactivate all plugins except Visual Composer, to be sure that this issue is not caused by a plugin, clear all caches and test again. Also check the values from system status: http://screencast.com/t/Wxky4KDu
max_input_vars should be above 2000 and max_execution_time should be 300.
Hello Andrei L.
I have been set the max_input_vars to 5000 all php.ini on php5 folder i have been set to 5000 but in my theme system status still detect 1000, why ?
And also, the mega menu still not get function and in the homepage the footer not show.
Why ? any tips ?
thx before
Please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
