Can you tell me how do I put my block titles from my homepage in h2?
On my website: lachainecrypto.com
Thank you
Hello MaximEvr,
You should edit the td_module.php and change from there the heading title for your blocks, like this -> https://www.screencast.com/t/jLYDOGfe
Hi !
thank Catalin you for your return, in the end my friend told me that pagination was in JS and suddenly I configured to have ?page=2 and the most problem for google.
Is AMP compatible with your theme?
thank you Catalin
Max
