Help to implement advertising in a block please
Good Morning.
Please could you be so kind as to help me, telling me what I have php template to include adsense code for advertising aperezca here:
ads
I use the Block 13
BLOCK 13
Thank you very much for the help!
Hello posonty,
If you want to add an ad after each posts using the Block 13, you will have to edit the td_block_13.php and use the do_shortcode method, using the Custom Ad 1 field. So, if you want to do this, please follow the next steps -> http://screencast.com/t/kIsAX0zAxk8E and the result you should see here -> http://screencast.com/t/qltnTvUbN
If you refer to something else, please provide more details.
I have done the following:
1) I added the code
2) custom_Ad_3 I added the code, which incidentally is not adsense, is another advertising company does like ?, I say this because nothing appears
ad
block13
  • This reply was modified 10 years by posonty.
Hello posonty,
Unfortunately, I do not know what kind of ad code you are using in our theme. First of all, please try to display the ad code using a simple Ad Spot and check the results. Please notice that our theme only renders the code that you have added and do not influence the functionality of it. Check your ad to be a valid one and if you have no success, please try to contact the provider of your ad code and check the functionality of it. This method which I gave you above is tested on my side with a normal ad using the div’s method and seems to work as properly and should work and for you.
