Hello.
We are using “Newspaper HISTORY” Theme (https://demo.tagdiv.com/newspaper_history/).
We want to make a Magazine Page that looks a lot like “Elle Magazine” whose website is: https://www.elle.fr.
Indeed, we want you to help us create the blocks on the part circled in the RED color on each of these screenshots below:
1 – https://imgur.com/a/wxmkW2U
2 – https://imgur.com/a/5eDdEDX
3 – https://imgur.com/a/EupbwES
4 – https://imgur.com/a/inaTcls
5 – https://imgur.com/a/psP0ieI
6 – https://imgur.com/a/G6h5Qos
7 – https://imgur.com/a/F5PUTD8
Please help us step by step.
We are blocked on the use of “Newspaper HISTORY” so that looks a lot like “Elle Magazine” whose website is: https://www.elle.fr.
Please, answer us through sample demonstrations in screenshots because it will help us best to quickly understand and solve our problem.
Awaiting your reply.
This topic was modified 4 years by
grezako.
1. The title can be centered: https://prnt.sc/moPe6HsHbv1G and you can create a border: https://prnt.sc/i7QwqGoxT8kc
For the blocks, you can use flex blocks and hide the details you do not need. For that line, I think you should add it by custom code: https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/ or use the element called “Separator”. For more details about the flex blocks settings, you can check this guide: https://forum.tagdiv.com/flex-block-settings-guide/
2. You can add the “button” element and styled it: https://prnt.sc/ptG2QcwiiS0G
2.-3.-4.The block can be build with a flex block and some “inline text” elements. Depend on which functionalities do you need on them(with or without links).
5. Same as at point 1.
You can add a row with 3 columns: https://prnt.sc/eUDHdi2O4tZM and add the number in an inline text element and set the style and add a flex block for the posts title. Check this video: https://www.screencast.com/t/LLtycCTxRhO
6.-7. For this you need some custom CSS in order to achieve it.
For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Thank you for understanding!
Thank you for your different answers but we are missing three important points to make our page similar to https://www.elle.fr/ to know how:
1 – put the Logo circled in Orange right next to the Title all circled in green on the following screenshot: https://imgur.com/a/WM6GS0R ??? How to add just a Logo just before the title of a Block ???
2 – put a small banner in yellow like the one on which they wrote “EDITION ABONNES” that we circled in blue on the same following screenshot: https://imgur.com/a/WM6GS0R ???
Thank you for answering us on these two very important points for us.
Please once again, answer us through sample demonstrations in screenshots because it will help us best to quickly understand and solve our problem.
1. Add a row like this: https://prnt.sc/DBuUmSkoHllV and insert the logo and an inline text element. Try to import a style of flex block from a demo: Music & Life or Chained News PRO demo like in your example, and you can adjust the category like this: https://prnt.sc/b6hhexPu0fhB
2. Change the color of the category from the flex blocks settings.
