Help visual Composer
I recently bought newsmag, the only thing is that I realize that visual composer do not have in my toolbar.
I installed all the files including js_composer.
Can you help me ?
screenshot
It is there, called WPBakery Page Builder. They changed the name of the plugin a while ago, check here
– https://codecanyon.net/item/visual-composer-page-builder-for-wordpress/242431
I thank you for your answer and tell me that you have to buy the license or the newsmag license enough?
thx
No need for any kind of activation or license, please ignore the activation messages
– https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/
We will provide updates for the page builder along with theme updates.
