You don’t need license. It’s a bundled version.
See theme docs:
https://forum.tagdiv.com/update-the-visual-composer-plugin-wpbakery/
The Visual Composer plugin that comes with the theme is licensed to the theme, the license specifies that only we can provide the updates and you don’t have to buy it or register it.
We’re testing the plugin latest version, if everything is ok we will include it in the next update and only then you can update the plugin by downloading the theme latest version and following the procedure presented in the plugin update guide.
Till then please ignore the update message!
