My AdSense ad is showing fine in the sidebar but I can’t get them to appear at the top and bottom of articles, can anyone help please?
Hello collinslad,
If you want to display your AdSense for each top and bottom post you have to use Article Bottom Ads and Article Top Ads from our Theme panel. Please ensure that you have introduced the correct Adsense code in order to achieve as you wish. These types of features are tested on my side and seems to works as expected. For more information about these, please consult our documentation here -> https://forum.tagdiv.com/article-ads/
Also, as you can see in our documentation, the theme only displays the ad which you has introduced in the corresponding field and this does not affect the structure of the code. Please ensure that your code works fine, otherwise, I suggest you to address at Google Adsense support because they will be able to provide a more accurate response regarding your Adsense code.
Hope this helps!
Thank you for the message!
Thanks for your reply but I have tested the AdSense code on another of my websites and it displays fine. It also displays with the Newspaper theme if I put the code directly into the post, but it doesn’t display when the code is put into the Top and Bottom ad sections in the theme panel.
I’ve worked out what I was doing wrong – sorry & thank you!
I’m running into this exact same problem also. Using Newspaper 8.
How did you fix this?
I’m not using this theme now, but from what I remember, I’d inserted the code into the wrong place. I was using smartlist 6 & when I put the code there, it worked.
@lighterside please provide a link so we can inspect the site and see why the ad does not work. It could be a smart list as @collinslad suggests. Smart lists ignore article ads.
