Help with background scale effect
Hi guys, i really need help, i have a row with 4 columns, in each one of them, i have setup 4 different background images, i need that, in case of making hover on the columns, the background images make the moveup&scale effect, or just scale, but i need a sort of movement when i make hover, i dont find any options for making this effect on tagdiv
this is the row
https://i.ibb.co/VHd1xtt/image-4.png
I recommend using another element, like a single background image, to create effects for the images. You can set the element in the columns.
