Help with block 14 configuration
Hello community:
I am looking for some help: I need to put in my home page a block like a 14th, but I only need that block with two columms; On the default configuration there are 3 columms, but I can´t find the style configuration. I Attach screen prints:
the default configuration:
Default configuration
The configuration that I need:
Configuration I Need
PD: I need the same attributes like block 14, only I want to change the quantity of columms.
Thanks for your help!!
  • This topic was modified 7 years by MikeKhero.
Hello !
You can achieve that by editing the ROW layout as you can see in my picture: https://www.screencast.com/t/YWU9WldyIPQ
I hope this is helpfull !
It works! So Thankfull!!! Thank you so much, have a great Day!
