Help with Block 5 title
I currently have the Black theme installed and I’ve changed the background colour to #000000 but the title text is no longer visible as the title text colour is 1A1A1A (to-module-title). Any help as I want to change this to #FFFF00.
I am not sure I fully understand what you are looking to edit, please provide more details.
Also, if you referring to this, you can change the color for text and background text => https://www.screencast.com/t/lYV0UXv7x
Thanks for your reply. Please see image attached, hopefully this explains it better.
https://www.screencast.com/t/AlIoGnVWkQfQ
Please provide your website link in order to inspect more into this issue.
Try to add this CSS code in Newspaper -> Theme panel -> Custom code -> Custom CSS:
.td-module-title a {
color: #fff!important;}
Replace the color with the color you need.
Thank you very much for your assistance. Works a treat.
