I need help with the following issue stated by my hosting agency:
You site code seems to generate a lot of connections per IP, as a result with 1 person visiting and clicking around it uses resources as though a number of people are visiting the site.
Kindly assist.
Also why is it that when I share my posts to facebook it previews a totally random pcture.
And how can I enable mobile ads?
Thanks for your quick reply.
Not sure what the issue is as every site makes these connections per IP so please ask your host provider to give you more specific informations related to this so we can check and give you a more accurate answer on this.
For the sharing system image issues please make sure that you install and use the WordPress SEO by Yoast plugin which automatically adds open graph meta tags to your featured image, used by the fb sharer to determine which image to grab. Make sure you use it then check your posts using this fb debugger tool to fetch new scrap info and test again: https://developers.facebook.com/tools/debug/
Let us know on this also and provide your site’s URL next time.
Mobile ads are enabled as soon as you add ads on your site so they should show up. Please provide more details on this.
