Help with customization theme
I need help with customization on my website theme https://www.aliall.store and make the same customization like on this web site https://aliclub.eu/ (same widgets, same positions, same posts view, cloning everything from there on my website). We use the same theme.
Can i please get help? i will send wordpress login info through email or here.
Hello Nikola Nikolov,
You should do it yourself and for this, you should use the Inspector Browser to see what kind of elements were used to be aware to add them on your theme, website. We suggest using the Inspector browser from here -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
I can’t do that, can i please get help from it.
Login info:
https://www.aliall.store/wp-admin
I have inspected your website now and I replicate it to look similar to your example. I guess that you are working at the same moment to your website. Check it if you see the results.
Good luck into your project!
