• Home
  • Showcase
    • Newspaper Showcase
    • Newsmag Showcase
  • Support
    • Newspaper Forum
    • Newsmag Forum
    • Blog
    • Documentation
      • Newspaper Documentation
      • Newsmag Documentation
      • The Theme API
    • What’s New
      • Newspaper
        • What’s New in v 11.5
        • What’s New in v 11.4.3
        • What’s New in v 11.2
        • What’s New in v 10.4
        • What’s New in v 10.3.7
        • What’s New in v 10.3.2
      • Changelog
        • Newspaper
        • Newsmag
        • tagDiv Opt-In Builder
  • Services
    • Web Development Services
    • Web Solutions & CMS Development
    • Web design & Front-end Development
    • E-Commerce Development Services
    • Page Speed Optimization Services
  • Buy Newspaper
Search
tagDiv support
  • Become a member
  • Sign in
  • Home
  • Showcase
    • Newsmag Showcase
  • Support
    • Newspaper Forum
    • Newsmag Forum
    • Blog
    • Documentation
      • The Theme API
    • What’s New
      • Newspaper
      • Changelog
        • Newspaper
        • Newsmag
  • Services
  • Buy Newspaper
Home Newspaper Help with file to customize tag section under post
jigglejello
#177190
Jun 7, 2017 at 7:17 am
Hello, I’m trying to figure out which file I would need to edit to customize the way the tags appear under my post’s.
I don’t want to use a tag cloud. Trying it out now but not really happy with it.
I would like to keep the tags at the bottom of the post but have them be in a dropdown menu like style, or maybe like a collapsible list (kind of like how collapse-o-matic does for text).
Any help is appreciated. Or if you could guide in the right direction to be able to accomplish this myself.
thanks
Simion C.
#177273
Jun 7, 2017 at 11:56 am
Unfortunately there is no option at the moment to style the tags displayed under the posts. The tags will simply be displayed below the post, like it can be seen in the demo
– https://demo.tagdiv.com/newspaper/10-landscapes-wont-even-imagined-exist/
You could maybe style them with css and change the way they look, but for more advanced customization probably you will have to use a plugin that can do that.
Here is a guide explaining how to use the browser inspector to identify the elements on the page and their classes, in order to create custom code
– https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
Amit
#180656
Jun 28, 2017 at 11:00 am
Hi Simion C.,
Im looking to put tags under each list item I create in a List post.
plz check this
can it be done
does this needs hardcoding
if it needs hardcoding then in which file
Simion C.
#180690
Jun 28, 2017 at 1:49 pm
The tags that appear in the post page are the ones assigned to that post, in the post edit screen. These are the only tags that will be called and displayed
– https://www.screencast.com/t/aZYqvpQz9Kba
– https://www.screencast.com/t/P0Gg2Uhsw
Each post template gets the tags of the current post and displays them
– https://www.screencast.com/t/g7YAePFMwi
The post content is restricted to what is entered in the post editor, you cannot place the tags inside this content.
If you are referring to something else, please correct me.
Amit
#180738
Jun 28, 2017 at 4:28 pm
Thanks Simion C.,
I’m asking about the placements of Tags,
Suppose I have a List post with 10 points,
  • point 1
  • Tag1, Tag2, Tag3
    Then can I display Tags below each Point as shown above
    Awaiting your insight on this
    • This reply was modified 9 years by Amit.
    Simion C.
    #180814
    Jun 29, 2017 at 8:05 am
    The post content cannot be edited dynamically. Like I mentioned, everything needs to be entered through the post editor and the theme will simply get the content
    – https://www.screencast.com/t/0qE9IfTO1wAV
    Maybe you can find a plugin that would allow you to do what you want, if there are any with this capability.
    Amit
    #180932
    Jun 29, 2017 at 5:50 pm
    Thanks Simion C.,
    Very kind of you to give support even when mine is expired.
    yes I researched and found that it can be done, but will require, custom code modifications including the database modifications, it will also make site quite heavy to load.
    an alternative is adding them manually.
    Thanks for all the help
    Tagdivians rule 🙂
    jigglejello
    Support Hours (GMT+2)
    Monday - Friday:
    8:00 AM - 17:00 PM
    Documentation
    • Newspaper
    • Newsmag
    Facebook Instagram Twitter Youtube
    Welcome to the Community! This is our main Support Center and, also the place where you can make new friends, people just as passionate about websites as you are. Don’t hesitate to ask for help as we are here for you. Thank you for buying our products!
    Contact us: contact@tagdiv.com
    • Home
    • Blog
    • Forums
    • About us
    • Support policy
    • Privacy Policy
    © tagdiv.com | Proudly made with by tagDiv. All rights reserved
    We use cookies on our website to give you the most relevant experience by remembering your preferences and repeat visits. By clicking “Accept All”, you consent to the use of ALL the cookies. However, you may visit "Cookie Settings" to provide a controlled consent.
    Cookie SettingsAccept All
    Manage consent
    Privacy Overview
    This website uses cookies to improve your experience while you navigate through the website. Out of these, the cookies that are categorized as necessary are stored on your browser as they are essential for the working of basic functionalities of the website. We also use third-party cookies that help us analyze and understand how you use this website. These cookies will be stored in your browser only with your consent. You also have the option to opt-out of these cookies. But opting out of some of these cookies may affect your browsing experience.
    Necessary
    Always Enabled
    Necessary cookies are absolutely essential for the website to function properly. These cookies ensure basic functionalities and security features of the website, anonymously.
    CookieDurationDescription
    cookielawinfo-checkbox-advertisement1 yearThe cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Advertisement".
    cookielawinfo-checkbox-analytics11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Analytics".
    cookielawinfo-checkbox-functional11 monthsThe cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Functional".
    cookielawinfo-checkbox-necessary11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookies is used to store the user consent for the cookies in the category "Necessary".
    cookielawinfo-checkbox-others11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Other.
    cookielawinfo-checkbox-performance11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Performance".
    viewed_cookie_policy11 monthsThe cookie is set by the GDPR Cookie Consent plugin and is used to store whether or not user has consented to the use of cookies. It does not store any personal data.
    Functional
    Functional cookies help to perform certain functionalities like sharing the content of the website on social media platforms, collect feedbacks, and other third-party features.
    Performance
    Performance cookies are used to understand and analyze the key performance indexes of the website which helps in delivering a better user experience for the visitors.
    Analytics
    Analytical cookies are used to understand how visitors interact with the website. These cookies help provide information on metrics the number of visitors, bounce rate, traffic source, etc.
    _ga2 yearsThis cookie is installed by Google Analytics. The cookie is used to calculate visitor, session, campaign data and keep track of site usage for the site's analytics report. The cookies store information anonymously and assign a randomly generated number to identify unique visitors.
    _gat_gtag_UA_43963494_11 minuteThis cookie is set by Google and is used to distinguish users.
    _gid1 dayThis cookie is installed by Google Analytics. The cookie is used to store information of how visitors use a website and helps in creating an analytics report of how the website is doing. The data collected including the number visitors, the source where they have come from, and the pages visted in an anonymous form.
    Advertisement
    Advertisement cookies are used to provide visitors with relevant ads and marketing campaigns. These cookies track visitors across websites and collect information to provide customized ads.
    IDE1 year 24 daysUsed by Google DoubleClick and stores information about how the user uses the website and any other advertisement before visiting the website. This is used to present users with ads that are relevant to them according to the user profile.
    test_cookie15 minutesThis cookie is set by doubleclick.net. The purpose of the cookie is to determine if the user's browser supports cookies.
    VISITOR_INFO1_LIVE5 months 27 daysThis cookie is set by Youtube. Used to track the information of the embedded YouTube videos on a website.
    YSCsessionThis cookies is set by Youtube and is used to track the views of embedded videos.
    Others
    Other uncategorized cookies are those that are being analyzed and have not been classified into a category as yet.
    CONSENT16 years 5 months 26 days 13 hours 25 minutesNo description
    yt-remote-connected-devicesneverThis cookies is set by Youtube and stores the user's video player preferences using embedded YouTube video.
    yt-remote-device-idneverThis cookies is set by Youtube and stores the user's video player preferences using embedded YouTube video.
    SAVE & ACCEPT
    Powered by CookieYes Logo
