Help with Flex Block 4
I want this to be like this sample
Please help
Please make sure you have the same settings for that block.
You can copy-paste the style https://i.imgur.com/uFwAN6N.png from a block on another block.
That’s the wrong answer. Actually you didn’t get my point.
I want this style to be like this one
I mean without featured image. Only text type
You can hide the image from the tab called “Layout” -> https://i.imgur.com/yvK6YoA.png on each module -> https://i.imgur.com/GeT5tmm.png
I did it but the text is going above
Please let me know if the title is from the block, or you add the element title to set it. https://i.imgur.com/UwncUhm.png -> https://i.imgur.com/n0RWYAK.png please check if you don’t have set some margin on the elements from the tab CSS -> https://i.imgur.com/CU0QFLz.png
There’s no margin set on the elements from the tab CSS. Plus the title is from the block.
Hello @iamratnesh!
We can take a look at this. Contact us via email at contact@tagdiv.com and provide the following:
– wp-admin (URL and credentials)
