help with grid
Hello
im using big grid slider . and using tags om it ..
i need to make the big image working on specific tag . and other 4 image working on another tag ..
in other word
i need to Choose the big image post and still stiky by using tag like breaking .. and other 4 photo working on other photo .
please help me
also how to add time to posts ?
Please take a look here is a solution for sticky post but this will affect all blocks: https://forum.tagdiv.com/topic/sticky-post-in-big-grid/
You have to enable date from post settings: http://screencast.com/t/RMbyfeFlii and change date format from Settings: http://screencast.com/t/BHbTo9rQzBh
Result: http://screencast.com/t/S70ZOLPfe
You can find more infos in Christopher’s tutorial: https://forum.tagdiv.com/topic/tutorial-how-to-add-custom-time-stamp-to-posts/
thanks alin
any chance to make bog photo work with tag . and othr 4 work with another tag ?
also please delete my site link from this post
https://forum.tagdiv.com/topic/very-big-problem-please-help-asap/
Unfortunately the theme doesn’t have an option like that and you would need additional customization for that.
If you don’t know how to do it I suggest you get someone to do it for you.
