Help with H1
Hi there, I need help. Neither Google or Bing find H1 in my Newspaper 6 theme. What can I do? I am no expert in wordpress, but I need some guidance in correcting this. Do I need to change something in header.php? Thank you for any inputs.
Hi JCAires,
You can simply add a text block to your page where you are able to place an h1(title) and some text content(description) – http://screencast.com/t/vo7rnIvDi3
Or you can use Pagebuilder with title template – http://screencast.com/t/8MwGVO2MqG the page title has the h1 tag – http://screencast.com/t/yVWkkEdW
Thank you for your reply. Was not to be supposed that a Page/Site title and a Post title would be H1? I do not want to change the layout, and I am confused. When I write a post, isnt its title an h1? If it is not, I will have to change all my labels in the posts, but still I do not know what to do with the front page of my site. Thanks a lot for any additional input.
Of course it is h1 for article title – http://screencast.com/t/FN50tyNB I was referring to your frontpage(homepage), if you want to have h1 you can easily add a text block using the page builder or edit your page and change the page template to Pagebuilder with title – http://screencast.com/t/8MwGVO2MqG
