Help with header and larger logo
Hello. We are looking to have a larger logo justified to the left with 468 wide ad to the right
How can we get larger logo image and format like shown in example below. Please let us know. Thanks!
Example – Curent
current
Example – Requested
requested
wanted to explain more. We want the full size logo you can see at ontheroadagaindad.com justified to the left edge and then a 468 x 80 ad justified to the right side.
Currently using Header Style 7 because it allows for full size logo.
We would use to justify the logo to the left edge as mentioned above with advert to the right side of it of it.
Hello TVDinner,
Please notice that our theme has a big list of header styles which uses the logo in different places, according to our documentation here -> https://forum.tagdiv.com/newsmag-header-styles/
Please keep in mind that we do not recommend to increase or decrease the logo from our header styles because you simply break the header layout. It’s not a simple task for this changing and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hope this helps!
