Help with images
I had big dreams starting my first blog.. and i can’t seem to get it off the ground because the images are so blury on mobile. I have spent so much money on developers from Odesk trying to fix this issue and every single one of them has taken my money without fixing the problem.
Can someone please have a look what the problem is ?
[data removed by admin]
  • This topic was modified 10 years by Andrei L..
I’ve removed your credentials as this is a public forum and any member can see them.
I’ve checked your site and the images are displayed fine on mobile devices: http://screencast.com/t/q9Rp6Rh5mw The theme uses thumbs to display images on modules and each thumb have a fixed size on both desktop and mobile devices. Please check this link for more details in this regard: https://forum.tagdiv.com/topic/feature-image-on-mobile-is-low-resolution/
The image is nowhere near the quality of that of the main slider.. how can i get it like the slider? it is not the same quality.. I see a BIG difference.. it has something to with these blocks…
Try to update the theme at V 3.1 which is available on themeforst, deactivate all plugins except Visual Composer, clear all caches, purge cdn files if you’re using then test the site again.
Let us know how it goes and if the problem persist please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
