Hello – I’d like to replicate this page using the mobile editor: https://www.pinkluggageabroad.com/hvar/. I’ve inserted the lead image but for the post, I could screenshot the image on the desktop and paste it in the mobile editor with a link to the post but that seems inefficient. Is there an easier way?
I do not quite understand, you want to set the featured image from the post and set a link on it ? if yes, then you can do it like this -> https://i.imgur.com/y1N1pVA.png and set on image the custom link -> https://i.imgur.com/odx210E.jpg after that set the link of your post.
Hope this will help you to achieve what you need!
Hi Calin – The featured image is fine, I was referring to the post that I had set up on the bottom of that page. I was hoping that the mobile site would either automatically pick up and display that post, or if there was a way (besides what you described above) to use the mobile editor to get that post in there. If either would be possible, let me know? Thanks.
From what i can see now you are using the responsive version -> https://i.imgur.com/xzxg36Q.png unfortunately the posts from desktop can not be reproduce on pages using mobile theme plugin, what you can do is to set the post link on featured image or on some text.
