Can you help me troubleshoot a problem with mobile search? I have 3 sites using Newspaper:
v 6.7.1 is working as expected
v 7.1.1 is working as expected
v 7.3 is not (problem occurred with 7.2 as well)
On mobile, the search window does not display when clicking the search icon. Can you help troubleshoot?
Thank you
Hello jciview,
I have checked your website and I saw that you have some js.erors in your console. These might come from your untested plugins which interfere with our theme and cause a lot of unknown issues. Please try to disable all of them, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
Hope this helps!
