Help with Mobile Theme on Newsmag
Guys, I need help.
How do I prevent the tagDiv Mobile Theme from using the mobile theme on the homepage only? I have special advertising positions on the homepage and a complete editorial organization, and the mobile theme doesn’t allow customization. I also can’t create a mobile version of the homepage in Page Builder (these options simply don’t appear, and I’m a Newsmag PRO user).
Oh, yeah… Also, I can’t get the login option to disappear from the mobile menu. It’s disabled in the theme panel, but it still appears.
Can you help me?
  • This topic was modified 1 year by Jeffmart.
The Newsmag theme provides the responsive version and mobile theme plugin for mobile versions. The Responsive version will display the desktop version adjusted for mobile, and the mobile theme plugin, if it is used, will have a simple layout that can not be edited. This is to achieve a better speed, and it is usually used for blogs.
If you want to use the mobile theme plugin, but you do not want it on the homepage, then you need to use the Gutenberg editor to edit the homepage and select the mobile icon – https://i.imgur.com/QK7YcB0.png – https://i.imgur.com/rfGLrQn.png
To disable the login you need to The theme panel > header > Sign In / Join – https://i.imgur.com/e04V50I.png and if the mobile theme is enabled, go to the theme panel > mobile theme > header and disable the show sign in / join – https://i.imgur.com/vw2VIqJ.png
