I just bought this theme to transition one of my radio stations to. I have a need to keep a couple of specific things from the old site. If you look at the site http://deportesdallas.com you will see an iframe at the top of the page which is part of the header.php, specifically <iframe width=”940″ scrolling=”no” height=”64″ frameborder=”0″ src=”http://espn.go.com/stations/feeds/affiliate/affiliateScoreboard” marginwidth=”0″ marginheight=”0″ bordercolor=”#000000″ allowtransparency=”” style=”position: absolute;top: -68px;z-index: 2;left: 50%;margin-left: -470px;”></iframe></div>
that we are allowed to use as part of our sports radio station. I tried to put that in the header.php on site I’m building with the newsmag theme found at the temporary url http://192.185.114.242/~deporte1. As you can see i’m not quite getting this iframe to the top of the screen. Please provide some guidance on if this should be done in the header.php or elsewhere in your framework
Thank you
Try to paste your iframe in the header template that you use, I see that you use default so try to paste it here above top menu: http://screencast.com/t/NifFOSQKjGoS also please use you iframe into a div(container).
