Help with "More From Author section" and "Previous and Next article" in post pag
In order to display contents in News Ticker section.I created a category called “Breaking news” and in “News Ticker” settings I filtered for “Breaking news” category.This is working fine.However when I navigate to a post added by me (http://www.newsmug.in/special-page/sumne-tilkondiri/%E0%B2%9C%E0%B2%97%E0%B2%A4%E0%B3%8D%E0%B2%A4%E0%B2%A8%E0%B3%8D%E0%B2%A8-%E0%B2%89%E0%B2%B2%E0%B3%8D%E0%B2%9F%E0%B2%BE-%E0%B2%A8%E0%B3%8B%E0%B2%A1%E0%B3%81%E0%B2%A4%E0%B3%8D%E0%B2%B5%E0%B3%86). At the bottom of the post there is a section called “Previous and Next article”,in that section Breaking news content added by me is displayed however I dont want “Breaking News” content to be displayed anywhere apart from News Ticker section.Same thing happens under “More From Author” section.Please help me resolve this issue
Note : Please take a look at my screenshot (http://www.screencast.com/t/P2xrdd5wZyH)
Thanks,
Anand
Hello Anand,
Unfortunately there is no option to control the next and previous post in the theme. You will have to alter the theme files to make changes to this section. The code for the next/prev post can be found here: http://screencast.com/t/86Lh2KFMr2ki
The same applies to “more from author” You can only edit the file and customize it:
http://screencast.com/t/ECzAXIyfAUL
This job will require a bit of php knowledge. If you cannot manage it we suggest you hire a freelancer to do it for you as we cannot offer custom work at this time.
